Best suspension mod without lowering car?
RE: Best suspension mod without lowering car?
I'm in the same boat as you. Lower springs are a no go, because of the hilly terrain around here. I'd replace the lower control arms first per CrazyAl's suggestion. It's a great bang-for-the-buck modification.
Here are the top three weak spots, as far as I can see:
1. Lower Control Arms
2. Upper Control Arms
3. Rear Sway Bar
If you're going with a one piece driveshaft in the future, then one of the control arms should be adjustable to correct pinion angle. If not, then you can save money and get the non-adjustable kind.
I'm very happy with my lower control arms. It's relatively inexpensive, too. Including installation it cost me about $300 - $350.
3. Rear Sway Bar
Is it possible to change the LCAs, rear sway, and/or panhard rod yourself?
Im fairly mechanically inclined, but not for things that shop should definatley do (like gears for example)
lower control arms - reduce wheelhop
shocks - ride quality
rear swaybar - reduce undesteer
there is a big difference between Falken RT-615's and Khumo MX's. The Khumos will last much longer. The Falkens get pretty hard after a lot of heat cycles, so their really not great for a daily driver.
I went ahead and ordered stangsuspension.com's in-house products: lower control arms and a panhard rod.
I'm just a daily driver, no racing, so I'm hoping these cheaper products will give me a nice feel over stock... I'll give you all a review when its over.
inyadreems
08-21-2015 09:10 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
