Hurst short throw shifter - should it have any give?
I got my short throw shifter installed the other day, a little notchy but I like it. I noticed though, like when i'm in gear, if i press it gently forward to back I can move it front to back maybe a quarter inch or so, like there's a little play front to back. Although it's very tight side to side in any gear, no play really.
Is this normal... or should I have the guy that installed it see if something needs to be tightened down more?
RE: Hurst short throw shifter - should it have any give?
ORIGINAL: howarmat
I have no play back and forth....only a little side to side.
There's two bolts attaching the stick under the boot and they're known to rattle loose (mebbe that's why you havethat play?).
Last time I tightned mine I used a dab of loctite and haven't had a problem since.
09-16-2015 07:53 PM
