question for you
RE: question for you
When you hit the rev limiter, that is bad, you should look at your tachometer and shift prior to reaching 5000 rpms, in most cases I personally shift around 3000. Only when it is necessary to excellerate fast should you go into the higher RPMS. If it were not for the rev limiter you would probably be in need of a new engine/
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
