h.i.d's blinking
Old Jun 11, 2007 | 11:45 PM
probinator's Avatar
probinator
Default h.i.d's blinking
well i installed my hids the other day and all was ok, and now I turned them on and one was blinking like a strobe and the other was out. Does anyone know what it is.
I bought them from stang mods.
Old Jun 11, 2007 | 11:50 PM
laredotexas's Avatar
laredotexas
Default RE: h.i.d's blinking
What year is your stang? On the 2007 the computer when no registering the light bulbs current sends this pulse signal that makes your HID blink like Strobes, you would need to buy a 60-100W resistor per sideor connect them to your high beams or parking lights with a relay.
Hope this helps.
Old Jun 11, 2007 | 11:53 PM
probinator's Avatar
probinator
they were working fine for like 2 days with no problems. now just one side started to strobe... mine is a 07
Old Jun 12, 2007 | 12:00 AM
laredotexas
yup, it happen to me the same way.. it takes around one day to start blinking.. no big deal just connect them to your parking lights with a relay.. they will work fine... or buy this resistors.. i was told by the shop where I got the HId that it would be some how hard to find them.I have not looked for them been that after the relay was install it has been workingfine. Now you will loose the ability of driving with your fogs lights on only been that they will be connected to your parkings.. but i also got HID on the fogs and drive with all 4 at onces.
Picture attached
Old Jun 12, 2007 | 12:10 AM
probinator's Avatar
probinator
Can u use the relay thats come with the lights or do u need to ad another relay?
Old Jun 12, 2007 | 12:16 AM
laredotexas
Yes, you should be avail to.. Just make sure you plug them to the parking lights or fog lights.. if you plug them to the low beams you will have the same problem..
GOOD LUCK
Old Jun 12, 2007 | 12:31 AM
probinator's Avatar
probinator
can you tell me where and what color you tapped into the blinker? I dont have a meter right now.
Old Jun 12, 2007 | 12:32 AM
laredotexas
Ok, Let me see. I would have to go out side and look i did not installed it my self.. but no problem give me a few seconds..
Old Jun 12, 2007 | 12:33 AM
probinator's Avatar
probinator
i appreciate your help man. its almost dark here. i know theres like 3 harnesses going into the main fuse block so they might have tapped it into there maybe.
Old Jun 12, 2007 | 12:46 AM
laredotexas
OK, im back..
You tap into the brown wire from the thinner wire group.. pictures attached.. I also posted pictures of my True 6K HID Lamp tought it would be funny, i have HID bulbs everywhere..
[IMG]local://upfiles/69914/3DAB2B94D6674820B1332964D298DDA4.jpg[/IMG]
[IMG]local://upfiles/69914/22D67D2DC163414DA2B41ED887669AB5.jpg[/IMG]
[IMG]local://upfiles/69914/273F61571CCE43F0BE0AEA33D49F787A.jpg[/IMG]
[IMG]local://upfiles/69914/090A63DCCE14435C9F165E928D082A6B.jpg[/IMG]
[IMG]local://upfiles/69914/9E511D22478646C1A278B10569D7B232.jpg[/IMG]
