'07 GT Hood Blanket
#21
RE: '07 GT Hood Blanket
Same here. And I have a v6... same hood...same blanket.
ORIGINAL: Fletch
That's what mine looks like too.
~Fletch~
ORIGINAL: wingman75
Its the hood of my 07 GT. The hood scoop nuts and clips can be seen.
ORIGINAL: Orion_240
Is that a new one? or one from a Calif. Special? Mine doesn't look like that. Is that part where your scoop attaches modified or stock.
I'll try to get a pic of my 2005 today. It has the 2 ponies.
ORIGINAL: wingman75
Here you go.
nineinchnail1024 you definately should have a hood blanket on there. As you can see on the driver's side that tan colored primer, or whatever, is showing. They just dont bother painting body color where the blanket is suposed to be.
ORIGINAL: underbird10
Bumpity, bump.
Come on, somebody has to have raised their '07's hood and snapped off a few....
UB10
Bumpity, bump.
UB10
~Fletch~
#22
Hood Insulator is there for noise reduction. Has nothing to do with heat or fire. The 2005-06 were made from a foam material. The 2007's are made from a fiberglass material. When I had my 2006 stang the insulator started sagging in the middle at about 2000 miles. Since I 'm in the industry I was able to get the 2007 insulator. No more sagging. Only porblem is that the holes for the hood scoop are in the insulators 100%.
As far as a tool to remove the push pins, there is a trim clip removal tool available at most auto part stores. Some have even used a kitchen fork to remove the push pins. If you are not reinstalling the push pin,a pair of pliers should work fine.
#25
ORIGINAL: Orion_240
ORIGINAL: wingman75
Here you go.
Bumpity, bump.
UB10
Bumpity, bump.
UB10
