Squeaky Poly bushings, revisited!
RE: Squeaky Poly bushings, revisited!
ORIGINAL: VWILLO
Anti-seize heh, did you clean out all of the grease first? I have been thinking of trying graphite, but haven't been able to determine if it will be too abrasive on the bushings. I'm disassembling and regreasing the outer flanges of the bushings every few months to stop the squeaking.
Clearly you have never used the silicone grease used for poly bushings. It sticks like snot. It can't be washed off, it's water proof.
ORIGINAL: 8178A
Grease is not a good solution because it doesn’t stay put on the bushings. Try NAPA Auto Parts silver anti-seize. It is super slippery and clings well to the bushings. Beware! It is very hard to clean it off of parts or your hands so be careful.
I have the BMR lcrs,reloc. Adj. pan and brace. No squeaks at all. But I greased them well at install with silicon grease ONLY. This is theONLY recomended lube for poly bushings.I also installed grease fittings in all bushings. They do transfer a little more road noise. But no squeaks. Petroleum grease will destroy your bushings.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
