what results at strip?
well my son inlaw talked me into seeing if the "HORSE" will run, i have an 06 gt withe a auto, got a jlp and a brenspeed tune. i'm going to put the 93 tune in it by means of 100 oct in the amount of 5 galons to top the tank off, hmm 6;50 a gal. anyways what times can i look for?
RE: what results at strip?
depending on the weight and your elevation and temp, but at this time of the year you will probably be looking at 13.8 or 13.9. wife has same set up pretty much as you except she also has larger throttle body and ud pulleys and she has ran a best at 13.5 last weekend but with no spare tire and she only weighs 115. good luck let us know how it turns out
Get some drag radials. It will improve your time and your fun factor i'm sure. If you get tires you can rev the engine and hold the brake, mash the gas to the floor and let go of the brake when the light goes down. You can't launch at all on street tires.
+1 on tires, makes all the difference. I've seen guys go to the strip without them and go home with thier tail between thier legs embarrased big time. These cars will not hook up on street tires at the strip.
09-24-2015 09:18 PM
09-08-2015 11:50 AM
