Clunking rear end noise
I am sorry if this is a stupid question.[&:]
I have an adjustable panhard bar made by BMR. Could it be causing a clunking sound in the passenger side rear? It happens on turns at lowspeeds. I added grease in the fittings when I installed it. I am just not sure if a panahrd bar could cause noise like this? Thanx
RE: Clunking rear end noise
You might want to get under there and check the passenger side bushings, i and atleast one other person had the bushings come apart. The panhard bar would then bang against the metal body mount.
If you are making a slow turn at slow speed and you hear the rear end,,,,,,,,take it to your dealer.
I had the same noise and so many others,,,,,,it took a few days for them to get the parts and fix it......Do it now.Jt
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
