How easy is it to install a shorty antenna?
RE: How easy is it to install a shorty antenna?
CAUTION, CAUTION,CAUTION, CAUTION............
This THREAD has been "hi-jacked" !!!!!!
DO NOT LISTEN to these "dumb people" !!!!!
YOU can "shorten" your own antenaee, with a pair of "sidecuts", and a small black wirenut.
WHILE taking your time, in determining which "shorty lengthis right" !
Start at 12 ", and GO to the length you LIKE !!! Depending on reception.
HOW hard is that?
DON'T SPEND your $$$$$ on "aftermarket shorties",... Think about that.
HOW hard is that?
Where did you get that one! I like it...I have an 8 inch but prefer that one.
ORIGINAL: wingman75
Now this is what you call shorty. 3-1/4" on my Stang.
ORIGINAL: mygt500
See my post above for details.
If you make it to the Woodward meet tonight I will most likely be there so you can take a look at it. You can even try it on your car if you want to. Bring a wrench to remove yours.
[:@]Remember to use some blue locktite on the threads
as the factory did. Maybe it will also keep someone
from casually removing/stealing it without tools. Also
be careful not to twist the mounting base where it goes
thru the fender when tightening up the antenna.[:@]
ORIGINAL: Maraman
im pretty sure you unscrew the old antenna and screw the new one in, but i may be wrong
