Kenne Bell Dyno results are in!
RE: Kenne Bell Dyno results are in!
Justin, The shop ended up rewriting the SCT tune that Kenne Bell supplied, The basline was pretty bad (352HP) with (323TRQ). He said every tune that has come from the different S/C companies never works well atthis altitude, So he has become well aquainted with what to do to make a tune that actually works at 6000'. It's kinda of a tricky deal, and it took him awhile and quite a few pulls to get it right.
ORIGINAL: Justin00Stang
That is probably going to be with a very high correction factor too, due to the altitude.
Yep stock block, I'm gonna build a forged block this fall, so I can squeeze some more ponies out of her!
ORIGINAL: probinator
is that on a stock block too.
A road trip to a lower elevation may spell disaster with a 10 psi pulley, so I will pass on that one until I put in a forged short block in her.
ORIGINAL: Stkjock
nice numbers...what a spot your in now.... take a road trip to lower elevation and get a pull done.....
Congrats!
Congrats!
I live in Denver, my car is the exact same color and wheels as yours.I don;t have a hood scoop though. I noticed your threadwhen you bought your supercharger. Did you install it yourself or have it done? Bad A$$ ride!
Hey Stan, We don't live too far away from each other, I live in Colorado Springs. I did the install myself over Father's day weekend. It took about 16 hours, but well worth it.
ORIGINAL: StantheMan
Are you running 91 octane with that 10 P.S.I. pulley. I live at 4500 ft. and was considering going to a 9 P.S.I. or 10 P.S.I. pulley (I'm currently runningan 8)but I don't want to worry about octane as we can only get 91 here. I asked Kenne Bell and they said don't do it, but they are at sea level. Would I need to have someone tune it, or is it possible it would be safe at this altittude because I'm not getting as much H.P. out of the car.
09-24-2015 09:18 PM
