Help going to the track tommorw...
and its my very first time. heres what i plan, first take evrything out of the car that i dont need lower the tire pressure to about 32 maybe 30 or so. its a manual so i guess i will try to rev to 2000rpm's and let the clutch out kinda fast. does any one have hints or tips, this is a stupid question i am new to a manual so what is powershifting exactly and should i try it tomorrow? thanks guys wish me luck my goal is 13.6 or 7. and if i do better which i doubt then right on. oh i am completly stock too.
RE: Help going to the track tommorw...
ORIGINAL: mattstang2007
You're just racing on "open to public" day, right? So you shouldn't be concerned with a reaction time(since the clocks don't start until you cross the timing beam) and just concentrate on getting your best launch(meaning 60ft times). If you're brave enough to "power-shift"(meaning shifting without using your clutch and timing the revs of the engine to bang the gears) go right ahead, but I would never do it on a daily driver that I still owe over $20K on[:@]. I think you might be better off just being very relaxed and shift your trans quickly, but with a open palm and guiding the shifter into the next gear, never forcing it. Yes, drive like you hate it, but with good technique. Best of luck!
Don't let the clutch out fast, faster than a normal takeoff, but not fast or you'll spin. Don't bother trying to power shift. Just try and shift as quickly as possible. I'd recommend you get a shift light, but since you'll be going tomorrow, it's not going to help you now. I'd shift right at 6k.
Toy around with the rear pressures. 25 psi works best for me, running the stock 17" wheels and Pirellis. Also, I raise the front to 40psi. Rev anywhere from 2000-2500. This is where practice is going to be needed. You gotta basically find a suitable RPM that won't bog you when you get on it, or one that will make you spin.
Power shifting is when you shift without letting go of the gas completely. (Or that's the defination I'm familiar with.)
I wouldn't bother removing the spare and what not... It's not going to matter all that much because you're just starting out. You should be more concerned with finding a comfortable launch.
I was just thinking it would be nice if i could set my raptor shift light to go off at two different rpm settings. Say I want to hold it at 5k without watching the tach and of course I want to shift at 6200. I suspose I could buy another one, but it might get confusing having two different lights going off.Not to mention the first light will stay on until I shift.
ORIGINAL: wingman75
I have an auto so I'm not going to tell you how to shift but I want to suggest you just shift as fast as you can without to much strain on the car until you learn how from experience. Don't sidestep the clutch with a lot of revs. You will get braver as you learn. If you have stock tires keep them at 32psi you'll have the widest contact patch. If you are lucky you might see a 13.7 quarter but don't be disappointed if you are at 13.9. Don't watch the tach watch the tree and as soon as you see the last yellow hit it. Let us know how you do. Good luck.
ORIGINAL: Menace
Why waste the time and hassle of removing the spare. lol. I've got the Shaker 1000, spare, and whatever gas in the car... and still ran 13.0. Unless you are seriously trying to break some time and need to shed the weight.. I'd keep it in.
