A warning for those with Tokico D-Specs
If you wash your engine make sure you cover the adjustment holes at the top of the struts. I was out for a spirited drive today and pulled over to tighten things up and the fronts were completely rusted up from washing my engine. If you notice on the cover caps they give you there is a small hole on top that water can get in. I don't know why they did that. I had to wait until I got home and spray them down with WD40 and break them free with a wrench.
RE: A warning for those with Tokico D-Specs
ORIGINAL: retfr8flyr
Mine have a screw on cap with a rubber piece on the top of the cap. There isn’t any way for water to get in.
Earl
Earl
A dab of grease will keep all moisture out!
exforbrian,
They are Tokico D-spec adjustable shocks and struts. VERY nice nice improvement when you lower your stang. Take less than 5 mins to be set up fromclose to stock ride to change to full race completely flat cornering and very stiff OR anything in between! (very easy to make changes)They are around $600 and 'can' be installed by yourself. The rears area no brainer and took less than an hour in my driveway complete. The fronts you have to remove remove the spring from the strut..... but can also be done IF you have some mech abilty.
You will not hear many complain about Tokico D-Spec......
exforbrian,
