so im tinting my tail lights and...
RE: so im tinting my tail lights and...
ORIGINAL: GTstangB.F.D.M.
well if i spray them face down, the paint wouldnt have come out even, or right.. bc the can would be almost horrizontal.. i thought aobu tthat b4 i did it.. but not for the reason that it could run.. i dunno .. whatever.. im not worried abou tit..
Not only do you want the lenses out for spraying you don't need to be spraying near your car for that matter. ...but whatever; just telling ya, no runs on a flat table top postioned object.
ORIGINAL: 157db
Spray those puppies flat. Hold can at 45 degree angle.
Try lighter coats as the manufacturer suggests.
Dont get in a hurry.
everyone including me did know this.. if you read, i said i was gettin impatient.. and also, while doing lighter coats with the clear coat, it wasnt coming out right, so when i did it a little thicker.. started looking like it should..
the tint spray went on fine.. and i did take them off the car.. i them on a table.. along with the thrid brake light..
i will try and get a pic up tongiht..
Not sure about rattle cans clear taking to 1000, then 2500 or 3000 wet sanding; might be fine, if so, cool, then hand polish with fine cut glazing compound and wax. Best of luck to ya!!
ORIGINAL: exforbrian
they sell a model tint that some guys did the tail lights on thier trucks it it turned out real nice, I would like to see this process
I hate getting behind someone with tinted tail lights. In the daytime hours, the tint makes it hard to see when the brake is applied. Tinted tail lights should only be used for show, cruises, off road etc. but on public roads.
