Installing longtubes soon...What do I do about the tune?
RE: Installing longtubes soon...What do I do about the tune?
Yes, it should. Also, keep in mind the different types of Dyno's. The Mustang dynotypically returns HP results 8-10% less than what a Dyno Jet will deliver. That was confirmed with my dyno today, which was a Mustang dyno. Just over 400 RWHP (in Hot Humid weather) , and on a Dyno Jet it was 443 RWHP (in Cool weather).
My question is a new h- pipe without cats and save about 1700 dollars or long tube headers and gain maybe 20 horsepower at peak? Where the other does about 8 all around?
Long Tubes (at least with FI) did not make any difference in HP rating. So, unless your willing to spend that money for sound (which I was) there is no gain in HP.
ORIGINAL: Sherwood06GT
So no gains from headers no gains from mufflers. The only thing to be gained from anything on the exhaust side is in the crossover?
That is the first I have heard of no gains with the longtubes, the general consensus is that they are good for 15 - 20 rwhp. Brenspeed told me earlier todayon the phone (and I am guessing they have plenty of experience) that they typically see 10 - 15 (which may be just for the catted versions). I hope, for the sake of S197s everywhere, thatyour experience was just a freak occurrence!
Yea, I saw no gains. But like I said, the LTs make an awesome sound! [8D][8D]
maybe you need some supporting mods and new tune...to get the added power.
ORIGINAL: Stkjock
Dude.... very difficult to believe...LTs are even a bigger pick up with F/I as long as you can take advantage of the added air-flow. I was considering it... and my tuner said 25-40 no issue.... as long as I had supporting mods needed to get there.... GT500 fuel pump and 60# injectors...as my motor would run out of fuel to get all that I could from LTs. I did not want to make my $1500 LT mod to become a $3000 mod... so I held off for now anyway.....
I would have the dyno shop adjust your tune to adjust your air fuel ratio. only takes a moment and ive read some posts where long tubes do you no good.. they are wrong. I gained 30 ft lbs of torque and 16 horsepower and that is after a 25 degree jump in temperature. you wont recieve a gain until you get your a/f adjusted properly. on mine I had to raise the wot fuel an additional 5% both on 2k-4k and 4k-7k. good luck.
