11 sec. bottle baby
RE: 11 sec. bottle baby
You don't need the pump unless you wanna do a real messy job, I installed the KB Boost a Pump, got from Brenspeed it works very well. Takes about 45 min with no messy fuel tank work.
I have a ZEX wet kit for sale with purge, blowdown tube, bottlewarmer, and cupholder swtich. It has only been run twice and am selling the car shortly. I will let everything go for $625 shipped! I have the 75, 100, & 150 jets.
I was pushing 125 through my car and only went lean when then nitrous came on. I called NX about that and they said it was normal as long as the car came back within a couple hundred RPM which it did. I never had any issues with plugs or anything else at that power range and the car is still running great.
I'm selling my Car so the Nitrous Express kit is for sale. 650 shipped for the kit with Blow down, Pressure guage and tube. for 700 I'll throw in the warmer as well. I need this thing gone. Last part that I have left of the car.
Seems a little scary if they say it comes back within a couple 100 RPM.....what if someone not knowing decided to hit it right around peak torque on a 4.6. High cylinder pressures associated with some NOS might offer a nice boat anchor.
NOS is a good tool but man if you don't know what you are doing you could break something fast.
Your lean condition was definately the fuel pump not being able to supply enough fuel, Been ther done that!, that's why with nitrous you will need a better fuel pump or a KB boost-a-pump. That's what I added and it fixed the problem.
ORIGINAL: PERTANO
09-16-2015 03:07 PM
