help on the 1/4 mile!
i have a 2006gt manual with 4.10 frpp gears, spyder driveshaft, sct tuner, lca, rear springs, rear sway bar, panhardbar w/ brace, tokico shocks and struts, and cervinis ram air hood with ram air kit.... i was lookin to be in the high 12s in the quarter mile will this be possible with the set up that i have? or will i need some other mods please help. thank you
RE: help on the 1/4 mile!
^^^ with good driving I don't see why not...um, are you running the stock air box 'cause a CAI (which I didn't see on your mods list) with retune and some drag radials IMO would cinch it...
You got good mods, you also might trythese fewthingswhen you godrag racing. Take offyour front anti sway bar andif you have Tokico d-specs adjustall fourto the softest setting, this will allow maximum weight transfer to the rear wheels when you launch.And ifyou can get a hold of somelightweight rear wheels with drag radials or slicks (you might be able to borrow some from another racer) put those on also. By just doing these things you should see at least a 1/2 second improvement over your existing times, that might even put you in the low 12 second 1/4 mile.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
