Lowering Springs?
RE: Lowering Springs?
ORIGINAL: SonicBlue05GT
i lowered my last car and considering you have to change out so many other components and then scrape every driveway, I won't be lowering another car.
I have the Eibach Pro Kit aswell and yes it does change the stance a lot. In my opinion it really makes the car look mean. Asfar as springs being worth the money, absolutly. Changing out springs is actually one of the less expensive mods to do. When it comes to clearing driveways and the rest....I have had absolutly no problems and this car is my daily driver. Obviously you have to use your head when approaching steep inclines and driving rough roads but its extremely easy to manage a car lowered at this height. I had never driven a lowered car before this and I find it very easy to cope with.
Before:
After:
This is where it can get expensive; As stated above, a panhard bar is reccommended aswell as adjustable lower control arms to correct pinion angle. Also aftermarket adjustable shocks are also reccommended as changing springs will lead to a stiffer ride.
Before:
After:
Eibach Pro kit here. If you really want the optimum ride you'll need to change out the shocks and struts as the stock ones are not ideal for this kit. Tokico makes and adj set of shocks and struts that are very popular on this forum (500.00). I haven't done anything other than the springs and I can live with the ride until I save the cash for upgrades.
Before
After
Before
After
BMR Springs here..I would suggest you get them, BUT if you want to do anything else..amass the parts..store them then do it all at once..
The stock hight is ridiculous, even with my drop..1.25/1.75 it still looks high to me..Never rubbed anything yet..
I changed everything cause i wanted to..my car handling is ridiculous now..it seems i cant push it hard enough into a corner..
I just ordered the eibach pro kit and can't wait till it gets here. One question, you guys with 18's - what size tires are you running? Did you stay factory or go bigger? Any problems with the bigger ones ie...rubbing, rougher rider, handing? Any info would help, Thanks
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
