question on my buddys CAI
#21
RE: question on my buddys CAI
it is normal......some genius here used a tie wrap
to hold it down slightly and the rubbing went away.
if you do nothing, a slight black spot will develope on
the air filter.....not a big deal....
ORIGINAL: yukmouth
so is it normal to have the jlt2 air filter slightly touch the hood when its closed?
#23
Run it down and then fill it up with Sunoco Ultra 94 (Actually 95).
Alternative: If the local Sunoco has GT100just go aheadand put 5 gal of GT100 in and then fill up with Ultra.
After that you can run 93 octane or Ultra if your bucks up.
PS: I know you are already done. Just though it might help someone later.
