What tire pressure should I be using ?
#21
RE: What tire pressure should I be using ?
ORIGINAL: Silos_and_Sirens
Question about load ratings...Stock 235 50 18 is 97, I am running 255 45 rear-101 load. How much difference is there in handling/safety with a 245 45 in front @ rating of 96? Something like 60 lbs of difference, any thoughts???? The 50 series is just too tall! I have seen the 245 45's in action and they are sick on an 8.5" rim, with the matching 255 45 out back.
http://www.tirerack.com/tires/tirete....jsp?techid=35
The BFG originals are rated for 1609 lbs max load, the 245 45s at 1565 (KDW but different from originals), 44 lbs difference. I doubt you'd exceed that load in any ordinary road, or even racing, circumstances. Your car probably weighs 3400 pounds all-up; 4x 1565 = 6260. Unless you jump it off a building, you're not likely to overload it.
Add the excess of 255 45 over the 245 45 ( 1709 vs. 1565) and you have an additional margin of safety. Looks like a "No worries, mate" situation, to me.
jwog666
12-27-2021 08:09 PM
