Sponsored by:
Sponsored by:
Speed of Sound (SOS) switch plate install (w/pics & vid)
Old 07-17-2007, 09:03 AM
TacoBill
TacoBill's Avatar
Default Speed of Sound (SOS) switch plate install (w/pics & vid)
I made the decision to swap out my Shaker 500 head unit with the latest Alpine DVD unit and also add a rear camera and a shift light. I wanted to be able to switch on/off the TR-7 video bypass, rear camera, and the Raptor shift light. I could have opted for some cheap toggles (which would’ve looked tacky), but instead found an awesome looking switch plate made by Speed of Sound.
I ordered the 4 toggle switch layout with a 2 1/16” gauge opening for no particular reason other than I really like this layout. I chose an Auto Meter Ultra-Lite II Voltmeter gauge and it fit the bill perfectly.
The SOS switch plate comes pre-wired with leads for easy connections. According to SOS, the switches and wires are sufficient for low-amperage (up to 15 amps maximum) applications. Any high-amperage applications will require heavier gauge wiring and relays.
Each switch has 3 prongs and typically get wired this way…
BLACK – Connected to common vehicle ground (used to illuminate the switch’s LED)
RED (center) – Connected to either a constant 12V or switched 12V depending on your application
RED (opposite end on black) – Connected to accessory circuit 12V in (In my case, Positive lead on Raptor, rear camera, and voltmeter)
Note: The Negative leads off the accessories get grounded to a common ground, NOT TO THE NEGATIVE LEAD ON THE SWITCH!
Switch panel
Auto Meter gauge
A Dremel was used to make a small hole in the bottom of the rear cup holder (after removal of the short cup base; pulls right out) to feed all the wires up to the switch panel.
My mess
The wiring can get a bit confusing so it may be a good idea to tape off each accessory and label it. Key here is to take your time and do one wire at a time.
Tip: To make soldering, heat shrinking, or wire twisting task easier, disconnect the spade terminal from the switch.
Each switch controls the Raptor shift light, rear camera, DVD video bypass, and the voltmeter.
Here are some pics and one video of the completed project.
Note: The reason why you don’t see the ‘DVD’ LED switch illuminated is because the video bypass circuit that the switch interrupts is less than 12V (or is momentary). I removed the Negative terminal off this switch since it isn’t needed.
TacoBill is offline
Old 07-17-2007, 09:10 AM
s2k
s2k's Avatar
Default RE: Speed of Sound (SOS) switch plate install (w/pics & vid)
Wow thats cool as fu*k!!!!!! I want that! How much did it all cost you for that SOS thing the player and the rear camera? If you don't mind me asking.
s2k is offline
Old 07-17-2007, 09:11 AM
Rdot9
DubStep Stu
Rdot9's Avatar
dang, thats cool, nice
Rdot9 is offline
Old 07-17-2007, 09:24 AM
TacoBill
TacoBill's Avatar
ORIGINAL: s2k
Thanks! The SOS switch panel is what makes it allcool!
The switch panel can be ordered directlyfrom SOS (see hyperlink in post 1). The rear cam I got off ebay, it's the Lorex SG4933R waterproof color camera, costs around $100. The Alpine model is the IVA-W205, a friend over at Alpine used his employee discount and hooked me up. [8D]
TacoBill is offline
Old 07-17-2007, 09:25 AM
TinPony
TinPony's Avatar
Awesome, I guess you don't drink coffee or soda
TinPony is offline
Old 07-17-2007, 09:30 AM
Rdot9
DubStep Stu
Rdot9's Avatar
^^^hmm mybe i should get one so my mom stops drinking tea in my car!
Rdot9 is offline
Old 07-17-2007, 09:31 AM
TacoBill
TacoBill's Avatar
ORIGINAL: TinPony
I do, but not in the car (only bottled water allowed!).
To be honest, I rarely used the cupholders anyway, so I don't miss them at all.
TacoBill is offline
Old 07-17-2007, 10:20 AM
TacoBill
TacoBill's Avatar
ORIGINAL: 157db
More flash than function IMO.
Wow! I'm getting slammed so early in the morning! [sm=lol.gif]
Not that I have to explain myself... but yes, I did use a few of those quick splices, and 2 crimp caps, but everything else is shrink tubed. Behind the stereo, all my power and ground wires, and voltage regulator are soldered and heat shrinked.
Could I have made all my electrical connections aircraft quality? Sure I could have. But I'm pretty sure I'll be fine the way it's all connected.
I have the voltmeter hooked up to the switch simply because I had 1 extra switch available. Sure, I could have ordered the 3 switch configuration, but I just liked the look of the 4 better. And since I couldn't think of anything to hook up to the 4th switch, I just went with a simple voltmeter. It's trivial more than anything, but it is more accurate than the +/- gauge in the dash.
btw, that poor soul that'll inherit my jalopy will be my son. [8D]
TacoBill is offline
Old 07-17-2007, 11:17 AM
torch red
torch red's Avatar
157..its time we see your car...
Show us all we are missing...
Well done Taco Bill..you rock..[sm=hail.gif]
torch red is offline
Old 07-17-2007, 11:28 AM
157dB
Cut & Paste Expert
157dB's Avatar
ORIGINAL: TacoBill
ORIGINAL: 157db
Would that be two stage Ford heatshrink or the lamo stuff
you can get at Auto-Zone?[:@]
157dB is offline
Quick Reply: Speed of Sound (SOS) switch plate install (w/pics & vid)
