To steeda or not to steeda
RE: To steeda or not to steeda
C&L and dyno tune here.
+1 most of it is the tune. C&L and JLT seem to get better results for people. However, it's most probably because they are buying them in a package from Brenspeed or B.A.M.A. and getting a custom tune.
If your not getting a dyno tune get a package from one of the reputable tuners, you'll see better results then from a canned tune.
JLT2 here. There are two choices - go with either the C&L or the JLT. I did the JLT because independent tests showed the highest gains (although only slightly better) and its cheaper than the C&L.
The C&L is a beautiful cast aluminum piece. If you care about looks thats the way to go. For the same or better peformance and most of all value go with the JLT - then use that extra money and get some UDP's or CCMV's.
So from what im reading steeda is not the better way even with the high flow inlet elbow??? I was reading that it had test proven 30+ rwhp results with a good tune... Im guessing this is just marketing hype???
I love my Steeda and SCT. I made a pretty good deal on mine so it was a no-brainer. I wouldn't offer a recommendation unless I had driven both, but I like mine, canned or not.
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
09-01-2015 08:16 PM
