Exhaust Rattle
Exhaust Rattle
So several weeks ago I put on my Flowmaster American Thunder single axle back muffler. The sound is great, but after a couple of days I started to notice that when I start it up and back out of the garage and then go down the driveway there is a pretty loud rattle. After I have left the driveway it usually is gone, and this usually only occurs when the car has been sitting for a while, so generally just the first time I drive it during the day. But in the past day or so I have noticed that it continues and is getting a bit worse. I don't think the bolts on the hangers are loose, I've checked, but the tip does move some, mostly up and down and it seems that this is because where the muffler clamps to the over-axle pipe there is much more movement than there was with the stock muffler. It seems that I mostly notice the noise when going at low speeds, and I'm usually turning and I seem to need to be in gear. Any suggestions or thoughts? Thanks a bunch.
RE: Exhaust Rattle
If it sounds like a metal agaisnt metal rattle sound, check to see if the catback is on all of the way. All you need to do is hop under your car and check to see if the catback is pushed all of the way up until it meets a rivet in the midpipe. If it isn't, then that is most likely your problem. Loosen the catback and push it up to the rivet and retighten as much as you can to prevent it from slipping out unexoectedly.
Might be the problem, might not. Let's just hope you get rid of that sound as soon as you can.
RE: Exhaust Rattle
I have Borla catbacks on my car and it did the same thing when they were first installed. Ended up being the metal hanger on the drivers side was a little bit too long and was rubbing against the inside part of the back bumper. Once the hanger was shortened (eh, about 1/2 inch) the rattle stopped.
RE: Exhaust Rattle
I'm having a similar sound when stock and which has gotten a tad worse since putting my FRPP Stingers on. I suspect a heat shield vibration. Seems to happen for me around 1100 RPM. I asked the stealership to look at it since I dropped it off last night for them to look at a few other minor things. I'll let you know IF they solve it (fat chance...).
RE: Exhaust Rattle
ORIGINAL: SaddleUp
RE: Exhaust Rattle
I had the same problem with my Flowmaster ATs, and just fixed it yesterday by re-seating the clamp. It didn't feel loose, so maybe since it's easy, you should just loosen it and re-tighten it, for grins. Worked for me.
I hate those queer clamps Flowmaster uses. I've read that a lot of people go use normal D clamps.
RE: Exhaust Rattle
I had the same problem. It was one of the hangers welded to the pipe touching the hanger sleeve they slide into. When I installed my x-pipe stuff must have gotten moved around on my Loudmouths and caused it to run slighty. No problem to fix just loosen and readjust your pipes.
RE: Exhaust Rattle
ORIGINAL: Nuke
09-24-2015 09:18 PM
