Gear swap questions...ABS?
I talked to a guy who will do my gears but he has never done a new Mustang. He wanted to know if the ABS system would be affected or if there was anything else that would surprise him.
Does anyone have any input?
Thanks a lot
Thanks a lot
RE: Gear swap questions...ABS?
The only trick with the abs is to remove the abs sensors from the brake plate before removing axles or they will be damaged when you push the axle in to remove the C clip. I did my own gears with a friend & they turned out great, neither of us had done it before but are both good shadetree mechanics. If your guy has experience with setting up gears go for it.
musnicki
09-23-2015 07:11 AM
jaiidutch
09-14-2015 10:29 AM
