Tire psi for 20s?
RE: Tire psi for 20s?
ORIGINAL: 157db
Tire pressure is tire pressure.
Not that dependent on rim size.
Run the pressure stated on your drivers side
door jam as a start and adjust for tirewear.
Rough example, these #'s are not accurate, but just to give you an idea what I mean.
Stock 18"'s at 32 psi have a load capacity of 1532 lbs (thats actually accurate)
Lets say you go to a 275/35/20. That standard load tire at 32 psi only carries 1246 lbs. (thats actually accurate also)
I say standard load, because some tires are extra load rated and can carry more weight at the same pressure.
I would be running 45psi in a standard load 20" tire.
Sidewall psi is only there so you know what not to go over, not what they recommend to run.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
