POST your DRILLED and/or SLOTTED ROTORS! (Spinoff)
RE: POST your DRILLED and/or SLOTTED ROTORS! (Spinoff)
ORIGINAL: blaven
You already saw mine but i'll post um anyways
These are my old rims with um
Here are mine, AP Racing 6 piston calipers and 14.25 inch 2 pc. rotors. Im using 20 inch wheels. Pain in the butt to find wheels to fit over the calipers. I must of looked at 50 different castwheels and only found 4 that would clear. Im sure that you could have a set of 2 or 3 pc. wheels made with a custom offset to clear but then the cost would most likely double.
[IMG]local://upfiles/53576/D1AD784745694D14ACA7F971E6206D85.jpg[/IMG]
[IMG]local://upfiles/53576/B127965A90E94D44999208FB2930EA01.jpg[/IMG]
ORIGINAL: Nichepi
I was forced to go to 19's with thebear. It sucks because you can't get any race tires in 19's.
God I hate it when pics are too big and I have to scroll across the screen. Maybe we could all work on sizing our pics correctly.
As for the Eradispeed plus 2's the rotors are about $600 for the front's. I have heard that the gt plus kit has issue's with clearence at the spokes but should fit an 18" whell so I have no idea why you would need 19's. If you get the rotor package then its 14" rotors and H/W to move the stock caliper outward and this shouldnt have clearance issue's. Moving the caliper out will give it more leverage which enables it to apply more torque on the rotor. It's also a 2 piece and is lighter than a stock rotor.
Disclaimer: Always check for fit with a template that most of the brake companies provide beforemaking your purchase. The Eardispeed plus 2's are what I am planning at this point.
http://rotorpros.com/index.htmis without a doubt the best option for not spending a lot of money. And if you get the Premium Version they already come with the hubs Powedercoated Black. The cost for the premiums is only like 30 more. He also has pads that I think only cost like 80.00 to add to the order.Here are pictures of mine prior to install.
Richard
Richard
ORIGINAL: schapman
The eradispeed front rotors weigh 19.5lbs on my non calibrated scale. Not sure if they weigh less than the stock GT rotor since I have a V6 (17lbs).
