Sponsored by:
Sponsored by:
Is something wrong with my car?
Old 08-10-2007, 02:53 PM
157dB
Cut & Paste Expert
157dB's Avatar
Default RE: Is something wrong with my car?
ORIGINAL: owero01
You should only shift into first after a complete stop. Even with the clutch in, its hard to shift into first. As for the idle issues, with the egine off an switch on, press the accelarator all the way to the floor slowly taking about five seconds to to it. Then release it the same way. If that doesn't work, remove the K&N and put the stock intake back on.
+1
downshifting into 1st while moving is killing her.
take it easy on the ol stang.
its not a racecar. its a v6.
157dB is offline
Old 08-11-2007, 07:43 AM
Stangrunner06
Stangrunner06's Avatar
Idle issue is normal, it is programmed in to puter for emission purpose, all std. shift cars do it, learn to live with it, and your CAI should be ok, I have the same with no issues. If the motor mounts and tranny mounts are ok, the shudder when shifting MAY BE due to releasing the clutch too fast, try it slower or with TC off, this may help if mechanically ok.
Stangrunner06 is offline
Old 08-11-2007, 02:13 PM
cmschlatt
cmschlatt's Avatar
the high rmp's in neutral are probably because you just started up your car and didnt let it warm up. it happens to me sometimes
cmschlatt is offline
Old 08-11-2007, 02:49 PM
kenthicken
kenthicken's Avatar
As for the idle issue, doublecheck your K & N install. You might have an air leak.
kenthicken is offline
Old 05-02-2008, 07:55 PM
danam
danam's Avatar
ORIGINAL: cmschlatt
I have same problem on my 05 Roush standard tranny. Its been doing it more last week or so becasue of cold temp? maybe. It drops from 750 rpm to about 500 goes right back up.
danam is offline
Old 05-03-2008, 09:23 AM
rogan01
rogan01's Avatar
Agree 100 0/0
ORIGINAL: 157db
ORIGINAL: owero01
+1
rogan01 is offline
Old 05-03-2008, 12:00 PM
grampa_stang
grampa_stang's Avatar
ORIGINAL: viperrmk
When I'm shifting in to first I'm doing about 15 MPH and I don't let out on the clutch. (while braking) clutch in, shift in to second let out a little, then clutch in while still braking shift in to first and dont let out on the clutch. I have never shifted in to first and let the clutch out while slowing down.
God never would I shift in to first to slow the car down, thats suicide!![&:]
Hmmm, This is ALL wrong. By shifting into 1st and not letting the clutch out...1. what's the point. and 2. That's called "riding the clutch", bad bad.
Next, the "(while braking) clutch in"...bad again...you're riding the clutch again. Then you state again "then clutch in while still braking shift in to first and dont let out on the clutch".
Riding the clutch again. The correct method is to "just brake" and pop it into neutral just before the RPMs fall low enough to "stall" it, and release clutch. Do not sit at a light with
it in 1st gear holding the clutch in...unless you're at the track of course.
Don't mean sound like an a$$, just trying to give you some pointers.The 1st car I ever drove and got my license with,had a manual.If I ever did what you're doing (riding the clutch thingy)....when my dad was teaching me to drive....I got a backhand upside my head.
grampa_stang is offline
Old 05-03-2008, 12:06 PM
Riptide
Riptide's Avatar
I know a couple people that sit at a light with it in gear and the clutch pedal all the way in. I've always been told this is a bad thing and hence try to avoid that habit myself. But those two guys both tell me it's not that hard on it.
When I approach a light I keep it in gear until about 1K RPM at which point I pull it out of gear. I don't put the clutch in. It will just slip out and won't grind gears. You have to time that right though because if the revolutions drop below about 850 or are above 1000 then it will grab and won't release w/o using the clutch pedal.
Riptide is offline
MXBT187
08-20-2015 02:36 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Mnuckolls
08-09-2015 08:54 AM
Mr. D
Wheels & Tires
08-08-2015 05:43 AM
Quick Reply: Is something wrong with my car?
