Sponsored by:
Sponsored by:
never seen this before or haven't noticed
Old 08-11-2007, 01:55 PM
dsavage
dsavage's Avatar
Default never seen this before or haven't noticed
just got done changing the oil-06 gt- After all is done and still on the ramps I start it up. the oil pressure starts to rise and then starts to drop. I immediately shut down and lookto see what I forgot which turns out to be nothing so in neutral I roll off the ramps and start again and everything fine.Any ideas.By the way,I use sat. newspaper section and stuff under oil filter and then toss away,best way I've found to keep oil off everything.
dsavage is offline
Old 08-11-2007, 02:54 PM
slammer1
slammer1's Avatar
Default RE: never seen this before or haven't noticed
Did you pre-soak your oil filter with fresh oil before installing it? It is always a good idea to do this. For cars that have a filter pointing straight up just fill it almost to the top. For cars with filter on a angle fill filter with oil, wait a couple of minutes then pour most of it out and install.
slammer1 is offline
Old 08-12-2007, 09:53 AM
dsavage
dsavage's Avatar
filled about 1/2,drove about 50 miles yesterday,oil pressure fine. thanks for the response
dsavage is offline
Old 08-12-2007, 10:06 AM
LegallyTorchRED
LegallyTorchRED's Avatar
It was on the ramps, not level, that's a pretty steep angle. That caused the OP / Gage problem.
LegallyTorchRED is offline
Old 08-12-2007, 11:05 AM
birdoffire7
birdoffire7's Avatar
ORIGINAL: LegallyTorchRED
That's what I was thinking.
birdoffire7 is offline
Old 08-13-2007, 12:08 AM
jerjan
jerjan's Avatar
+1 on always pre-filling the filter.
jerjan is offline
lincolnshibuya
12-08-2015 04:37 PM
Dokilar
15
10-16-2015 08:13 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
UrS4
09-30-2015 10:13 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: never seen this before or haven't noticed
