Sponsored by:
Sponsored by:
I have an engine light on my dash but no code...
Old 08-15-2007, 11:21 AM
mAnYsTyLeS
mAnYsTyLeS's Avatar
Default I have an engine light on my dash but no code...
Any idea why there isn't a code appearing? I just had Long Tubes and an Off road H pipe installed. Oh and 3.73 gears. Let me know what you think...thanks!!
G
mAnYsTyLeS is offline
Old 08-15-2007, 11:23 AM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: I have an engine light on in my dash but no code...
reset it and see if it comes back....
howarmat is offline
Old 08-15-2007, 12:14 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
I don't think I can. It's just a little light that looks like an engine that's lit up. When I go to the message center...there's nothing there that says Check Engine or any codes.
Old 08-15-2007, 12:15 PM
hammeron
hammeron's Avatar
Default RE: I have an engine light on my dash but no code...
this light?
[IMG]local://upfiles/37808/6249D1B921354BBF9A3B13F72FBBDCEF.jpg[/IMG]
hammeron is offline
ollied
ollied's Avatar
You may need a special tool to read codes from the ecu
ollied is offline
Old 08-15-2007, 12:18 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
Yep....that's it!
ORIGINAL: hammeron
this light?
Old 08-15-2007, 12:22 PM
NickSezz
NickSezz's Avatar
Did you try to read the code with your tuner at all? Its probably due to your new long tubes. The engine light will take a few miles to come on because the computer has to gather enough info about a problem before it will trip the light. Also, it may take some more time before the computer will give a code because it has not fully diagnosed the problem yet. If this is the case the code p1000 should come up (testing imcomplete).
NickSezz is offline
Old 08-15-2007, 12:23 PM
hammeron
hammeron's Avatar
i'm gonna have to put my money
on a tune issue. it seems that your current
tune isn't jive'n with the equipment
hammeron is offline
Old 08-15-2007, 12:43 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
Thanks everyone. I'm going to be in Europe for the next 3 weeks...but when I get back, I'll make sure to get a custome dyno tune for my new parts. Take care!
Old 08-15-2007, 12:49 PM
hammeron
hammeron's Avatar
bon voyage'
hammeron is offline
Quick Reply: I have an engine light on my dash but no code...
