Help my 60'
RE: Help my 60'
ORIGINAL: Dex
think i should go to 3.90's?
RE: Help my 60'
ORIGINAL: Dex
thanks for the info. looks like im lowering my tire pressure. some other guy told me 12psi so thats what i'll do.
You spraying in 1st?
You def. have the modsfor a good 60', just play with the tire pressure and your RPM at launch and you will get it no problem, just takes time.
The 3.55's are perfectly fine. I thought about going to 3.73's, but it just wasnt worth it imo. Im not quite sure when your turbo spools and all that so gears may help you more than they would help me, but you def. have a 1.7 60' in your car as is.
RE: Help my 60'
Turbo spools with my 2 step so im getting the power but i may be bogging a we bit. next time out I'll try 10-14psi in the tires.
When i went down the left side of the track I kept breaking loose. I thought it was my tire pressure so i aired up but then i went down the right side with no problems. I went down once again on the left and broke loose again. I think it was just that side...oh well, first time out Trial and ERROR
