going to the track this friday
RE: going to the track this friday
ORIGINAL: 06VistaBlueGT
I couldn't launch above 1500rpm's on my "fat" street tires. I installed a set of Mickey DR's and I can now launch at 4k with no tire spin. My et's went from approx 14 to 13.65. Street and track are completely different as far as traction goes. I doubt you'll be able to lanch about 2k rpm's with your street tires. Good luck, I'd love to see you get that low 13.
Also, I have a 93 race tune from B A M A and lca's set to the agressive low setting. I have tokico's that I adjust stiff on the back and soft on the front and I run with no front sway bar to promote weight transfer. 2 things holding me back; driver skill and the track has a slight incline.
ORIGINAL: brendend
im preaty good at launching, and i got some fat tires in the back. 275s
ORIGINAL: brendend
You will most likely run a low 14 due to traction issues on street tires. Come back when your done and tell us your MPH and you can kinda determine about what you would run on DR's.
I run my Mickeys at 10 psi, pulled a 1.69 60'
Street tires, no matter how wide they are you wont get traction for ****, i dont care if they are 335's
not to thread jack but what psi are you running, what mph and duration of burnout (I've been told 30 mph, 5 seconds on mickeys, 18psi)...and are you dumping the clutch, easing it out, also what short times are you pulling? thanks...
mungodrums
09-28-2015 10:54 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
mungodrums
Suspension
09-24-2015 10:12 PM
