going to the track this friday
i have a auto with brensped 91tune, c&l intake and slps(not that they do much other then sound) im taking out my spare and all everything else not needed in my car. she runs strong as hell and im chirps 2nd and 3rd if that tells you anything. what should i expect? according to the weathers its going to be in the high to mid 70s when im gunna run. what kind of times should i expect? my friend is saying low 13s by the feel
RE: going to the track this friday
ORIGINAL: brendend
im preaty good at launching, and i got some fat tires in the back. 275s
I couldn't launch above 1500rpm's on my "fat" street tires. I installed a set of Mickey DR's and I can now launch at 4k with no tire spin. My et's went from approx 14 to 13.65. Street and track are completely different as far as traction goes. I doubt you'll be able to lanch about 2k rpm's with your street tires. Good luck, I'd love to see you get that low 13.
Also, I have a 93 race tune from B A M A and lca's set to the agressive low setting. I have tokico's that I adjust stiff on the back and soft on the front and I run with no front sway bar to promote weight transfer. 2 things holding me back; driver skill and the track has a slight incline.
I ran a 13.7 @ 105mph with the mods in my sig. I launched at 2000rpm with out any spin after scuffing the tires a little. I'm sure the O/R H-pipe helped alot so I think on a cool day like friday is supposed to be you might be right around the 13.8-14.0 range. I'm going on friday too and am hoping to run a 13.3-13.4.
