Need Help Can't Figure Out
I have a 2007 GT w/BBK CAI and BBK throttle body, SLP loudmouths.No tune then.(Have one now).OK this started the other daywith a long run on the interstate. I noticed a rattle under the car. I thought it was the cats. It had thattypical broke-up cat rattle. I ordered a new Basani X w/high flow cats. Installed it -still rattles. Took SLP Loudmouths off and found all the welds on the inside of both mufflers broken. OK that would cause it to rattle. Re-installed stock mufflers w/ Basani X. Still rattles. Could I have burnt the valves or could it be valve rattle? Does it with or w/o the Brenspeed tune. I also have lost a lot of torque after installing the Basani X. It doesn't feel the same. No check engine lights, tach is steady as can be on idle. You can rev it up in the garage all day and not a rattle, only when your driving it. Before the Basani X it had great power but rattled, engine seems to run good. Reved up the motor with the hood up and it sounds great. Sounds like it could be coming from under the car. Can't figure it out. Wouldn't I see some signs from the motor if it were damaged.(Check engine,rough idle etc.)Please Help. I am considering returning everything to stock and take it to the dealer.(8500 miles). I am getting the guys that did all my custom mods to look at it tomorrow, they are pretty good.
RE: Need Help Can't Figure Out
I can't tell if it's around the radio or coming from the back. Sounds like it's under our feet sometimes. If it was engine trouble(valves)I would get rough idle and engine light right? i have not checked the heat shields.
https://mustangforums.com/recalls-and-tsbs/tsb.htm
They don't have the 2007 up yet
ORIGINAL: mechanicterry
there are no welds inside SLP loudmouth "mufflers"
If you remove the SLP muffler and look in from the back you will see an inner liner that is welded in with three small tack welds. It allows some air to be trapped to give it a "rumble" sound. All three tacks are broken on both mufflers and allowing that liner to vibrate. Hence the rattles. But unfortunately there is more to the story and I just have not found it yet.
