Denny's Driveshaft Questions
I searched the forum and didn't find anything, so I figured I'd ask.
Do any of you use or have found a reason to use a DS Loop? Wasn't sure if Denny's needed one or not.
Also, I read that some driveshafts won't work with a lowered car. Is that true? I just ordered my lowering springs today, so if that's true - well it's going to suck. [>:]
RE: Denny's Driveshaft Questions
The drive shafts will work. If you lower your car, you may have to install an adjustable upper control arm to correct the pinion angle. The loop is for safety purposes. If the ds breaks, then the loop keeps it from dropping and possible causing damage to your car.
ORIGINAL: JaysFreaky
I'm going to be installing UCA and adjustable LCA the same time I lower the car. Will that setup be like the adjustable UCA?
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
