Speaker rattle
RE: Speaker rattle
Check my post here. i don't feel like retyping that post all over again.
https://mustangforums.com/m_3753404/tm.htm
RE: Speaker rattle
ORIGINAL: fastmxer9
I just started getting an annoying rattle coming from the driver door when i play music. The music is never anything loud. anyone had this before and found out the cause?
Sorry, not a helpful answer, I guess.
RE: Speaker rattle
ORIGINAL: mightymouse
RE: Speaker rattle
Small flat head screwdriver with a piece of cloth wrapped around it and gently pry off. I replaced the stock speakers several weeks ago, and thought maybe I had not gotten the plate back on right. There are actually 2 plates (3 if you count the little sail piece at the top). 1 plate behind the door handle (I think this is my problem) and one behind the handle you use to pull the door shut (it's a bigger peice and seems like it fastens much more securely)
Turning up the music only half helps for me. I know that damn thing is still making noise! [&:]
AmericanMuscle4.6GT
11-10-2015 02:06 PM
breaking
10-02-2015 01:27 PM
