Sponsored by:
Sponsored by:
OFF ROAD X PIPE TROUBLE????
Old 08-27-2007, 07:56 PM
07GT4.6
07GT4.6's Avatar
Default OFF ROAD X PIPE TROUBLE????
Hello everyone, got some problems with an offroad X pipe i installed on sat, i get a vibration on the center console by the pass side, also the car seems to resonate loud you can feel it on the floor boards in the past ive had x pipes beforebut is been on the 5.0 diffrent carr all together, but never got the floor board vibrations.Im running stock manifolds with a MAK offroad pipe stock mufflers any one had this problem before.I checked the hangers and the pipe all together and nothing is rubbing the body any leads will be greatly appreciated.thanks.
07GT4.6 is offline
Old 08-27-2007, 08:01 PM
ohsixgt1217
ohsixgt1217's Avatar
Default RE: OFF ROAD X PIPE TROUBLE????
Its gotta be banging up right underneath your feet. Adjust it.
ohsixgt1217 is offline
Old 08-27-2007, 08:05 PM
howarmat
s197 Junkie
howarmat's Avatar
my floor vibrates with my o/r h pipe......i guess its more of a rumble....just the nature of an o/r pipe i would think
howarmat is offline
Old 08-28-2007, 05:01 PM
D_Gusler
D_Gusler's Avatar
I agree with the rest. just a characteristic(sp) of running any type of off-pipe on these cars.
D_Gusler is offline
Old 08-28-2007, 10:25 PM
jerjan
jerjan's Avatar
Check the two hangerhooks that attach to the transmission x-member rubber mounts. My rightside hookwas hittingthe steel x-memberand I had to bend it up to cause the pipe to hang lower. You will need a torch to do it if is like mine was. The stainless mount hook is very strong and will not bend unless it is heated.
jerjan is offline
Old 08-29-2007, 11:56 AM
07GT4.6
07GT4.6's Avatar
Thanks for all the leads i will put it up today and see what shows thanks.
07GT4.6 is offline
Old 08-29-2007, 12:28 PM
hogpowr
hogpowr's Avatar
Mine was similar, the resonance was so great as to cause headaches,.........it was the hanger just barely touching the mount(on the x-pipe) several taps with a sledge hammer and perfect, still loud just no vibration or resonance.
Good Luck!
hogpowr is offline
Old 08-29-2007, 01:43 PM
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
+1 on checking all the fittings and hangers but the vibration is definitely there, alot more so than the fox body 5.0's. I had 2 chamber flowmasters and o/r x pipes and it was a mean rumbles. With S197 its just plain raspy as hell, alitlle too loud for my liking. But it is what it is. I wonder if the o/r h pipe is less raspy. Any thoughts?
MELLOWYELLOW06 is offline
Old 08-29-2007, 04:19 PM
howarmat
s197 Junkie
howarmat's Avatar
yes....h over x for deepness any day
howarmat is offline
Old 08-30-2007, 07:52 PM
07GT4.6
07GT4.6's Avatar
Yeap stupid me put the car on a lift today and my buddy found the RT hanger on the X pipe bearly touching the trans X member causing the vibration and the resonance he bent the hanger MUCH NICER TONE no vibration NOW I LIKE KICK A$$.
07GT4.6 is offline
CS2007
06-25-2019 09:45 PM
chrisdbassplayer
10-13-2015 06:53 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
ChampInSD
10-02-2015 04:55 AM
09-24-2015 09:18 PM
Quick Reply: OFF ROAD X PIPE TROUBLE????
