Sponsored by:
Sponsored by:
Old 10-22-2015, 07:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
DIY THROTTLE RESPONSE MOD (MUST SEE!)
Old 12-15-2010, 08:17 PM
  #491
MustangFirstCar
MustangFirstCar's Avatar
If a CAI/tune speeds up your response, and this cuts away the lag, imagine what they do together!
MustangFirstCar is offline
Old 12-16-2010, 03:35 PM
  #492
157dB
Cut & Paste Expert
157dB's Avatar
Just anticipate and mash the throttle sooner.
Throttle lag gone without the mod...
157dB is offline
Old 12-16-2010, 05:54 PM
  #493
jamesgribley
jamesgribley's Avatar
Originally Posted by stealth_GT
Ask Toyota.
^^^ This was my first thought when I saw this thread....
gribley
jamesgribley is offline
Old 04-11-2011, 10:36 AM
  #494
UltraKla$$ic
UltraKla$$ic's Avatar
Thumbs up
Originally Posted by mach1351
This may help some people that don't want to mess with the tiny wires.
I decided to fix the dead space on my 07 GT throttle since I had about 3/8 inch of travel with no engine response.
I followed Tube's advice and took the pedal assembly out and removed the 5 torx screws when I noticed the cover that holds the circuit board has slots where the screws go through it. This allows quit a bit of travel. If you push the cover forward (at the top where the plug is)as far as it will go and tighten the 5 screws, you accomplish the same thing as bending the brushes to reach fartheralong the board.
I tried thison myMustang and now it has no dead space. If you need more travel you could easily open the slots a little further.
I also want to thank Tube for finding and posting the fix for this problem otherwise I would have had no idea where to lookto fix this. Hope this helps some others. BTW the car is much smoothershifting now.
JB
Just did mine like this without having to bend anything. Just "clocked" the top of the cover where the plug is forward(towards the firewall) and all is good. Instant response on the pedal now!!!
10 minutes max spent on doing this mod!!! WELL worth it!!
Thanks for this tip!!
UltraKla$$ic is offline
Old 04-11-2011, 04:45 PM
  #495
pascal
S197 Section Modder-ator
pascal's Avatar
This thread's only 4 years old, where have you been son??
pascal is offline
Old 04-11-2011, 05:20 PM
  #496
X3xMONGOOSEx3X
X3xMONGOOSEx3X's Avatar
In a hole
X3xMONGOOSEx3X is offline
Old 04-12-2011, 01:00 PM
  #497
ccbulldog
ccbulldog's Avatar
Just saw this thread for the first time. Does anyone know if any of this applys to the 2011s? do they still have the same pedal electronics box and is the does the same problem still exist?
ccbulldog is offline
Old 05-19-2011, 01:12 AM
  #498
La Porta
La Porta's Avatar
So I'm anxious to try out this "rotate the cover" thing before getting to actually bending wires. I'm still a little confused from the descriptions given by the people here. Anyone have pictures of what exactly is involved in this?
La Porta is offline
Old 05-19-2011, 01:47 AM
  #499
tigercrazy718
tigercrazy718's Avatar
man i cant believe this thread isnt a sticky. i have never heard of this before and it seems like a fun mod to do. ill prob do this soon since i have nothing to do for the next 2 weeks lol
tigercrazy718 is offline
Old 08-29-2011, 07:03 PM
  #500
NickS_
NickS_'s Avatar
OK, quick question.
I have a REV 4 part number "4R33-9F836-B" and I noticed the 07+ have different numbers.
Could you put the REV 1 part (the newer one) in to an 05-06 with no problems; has anyone done it?
Thanks
NickS_ is offline
Quick Reply: DIY THROTTLE RESPONSE MOD (MUST SEE!)
