got around to taking some pics
Hey all, since my baby is clean i got around to snaping some pics. So here she is.
[IMG]local://upfiles/40549/EBC68D3891A24E3EA60FE7699956BA7F.jpg[/IMG]
[IMG]local://upfiles/40549/7C8728A863B44A62AD2D897ED36037DE.jpg[/IMG]
[IMG]local://upfiles/40549/1DC304A34A6D44C0A759A0F4EB171C74.jpg[/IMG]
[IMG]local://upfiles/40549/46EE1861CE924B9A95B24B81CCCFDB79.jpg[/IMG]
RE: got around to taking some pics
it's not the shacker scoop it's after market. in about a month it will bea working scoopthough. it wont feed cold air to the intake but will help with cooling under the hood.
ORIGINAL: mightymouse
I've thought about an aftermarket hood that has heat extraction vents such as the Saleen but I'm not yet willing to part with a $grand just for the hood (then theres paint $$). Plus, I like the scoop which the Saleen doesn't have. Though the Saleen hood might look good with an aftermarket scoop, I don't think I'm quite down with that yet - at least I haven't seen one like that yet.
So, right now I'm just kicking around a ram air hood - keep the scoop and supply outside air to the intake (not forced air, just some outside air when the car is moving).
How do you plan to modify your scoop/scoop hood area to perform as a heat extractor?
Thanks.
I'm going to go a head and cut the hood open where the shaker system would go. Then I'm going to cut open the front of my xeon scoop to open up the two long runnersthat are behind the front coversand there you have it a working hood scoop the will assist with cooling under the hood. there are other small things like something to cover theedge of the cut out on the hoodas well as more3M tape to hold the scoop on the hood. This should work out well..
Heat will fallow the path of least resistance. if the fans are blowing the het back off the motor and since heat rises when the car is at a stop you should see a lot of heat comming out of the scoop and when the car is in motion some level of cool air should pass through the scoop helping push the temp down under the hood.
