lol electric turbo chargers?
RE: lol electric turbo chargers?
I like the concept, and have thought about this before, but after consideration, I doubt that these systems would be effective. It comes right down to the reason you have a V8 instead of a 4 banger, I just don't see a 12 volt electric motor being able to deliver the necessary force to put air under pressurethe way a mechanically driven blower can.
It produces 6 psi so technically this should work. Only thing is I don't know if it's gonna last. But seriously, for something to force the air into the engine, it does not necessarily have to be belt driven or spun by exhaust gases-- it could be anything that can blow the air.
ORIGINAL: olvanish
This technology looks interesting. It's cool that someone is thinking outside the box, but I'm kind of wondering if something this easy could be done, it would have been done already.
I wonder if it would be reasonable for a high-amperage alternator to take the place of the four batteries? If that were possible, then it would seem reasonable for this to actually work.
This seems like essentially the same thing as a procharger, really the only difference is that instead of a using a belt to get power from the crankshaft, the electric motor is drawing power form the alternator, which is powered by the crankshaft. It seems like the procharger would be more efficient, but the electric turbo may be easier to mount, since it's not restricted by a belt.
Inefficient, because the elec. motor is say, 80% eff (the general Power Factor of induction motors is 0.8), which must get its power from the alternator, which is also 80% eff, which gets its drive from the engine.
mrappe
09-26-2015 10:16 AM
