is this idea possible?
RE: is this idea possible?
ORIGINAL: explict
Nitrous sounds right
maybe even turbocharger. They usually dont start making boost until the throttle is up there
Andrew
ORIGINAL: androdz
Wrong again, the new turbo's are already at max boost at 2,800 revs. So you have a flat powerband from 2,800 to 6,500 unlike a supercharger that keeps increasing boost. For example a centrifugal s/c on a 14 psi belt will make the 14 psi at the redline while the turbo will be @ 14 psi 2,800 with no parasadistic loose. Thats why they are > than s/c's
Andrew
ORIGINAL: explict
Andrew
that's about the best typo I have seen in a long time!
para-sadistic
sorry I usually don't like messin with people trying to make a useful reply, but I could not let that one go by.
Superchargers are direct driven off the crank pulley and are thus "always on." You can't flip a switch to "engage" or "disengage" The reason boost doesn't show up till the higher rpm's on a centrifugal is because the impeller speed isn't high enough to compress the air. On a roots type (like the Roush, Whipple, etc) boost come up right away because they are positive displacement type compressors. The only exception is like what was mentioned in a previous post about the bypass valve staying open until there's enough pressure to close it and cause "boost." But even in that case, the supercharger is still spinning it's just that the excess air is being recirculated back to the intake side of the SC so no boost is created.
what if you got a clutch on the pully like the a/c compressor? the pully is always moving when the engine is on but the compressor isnt always going? could you use the same idea for a s/c?
ORIGINAL: brendend
on centri it would work
ORIGINAL: MantaDreams
uh... parasitic?
para-sadistic
ORIGINAL: androdz
Andrew
ORIGINAL: explict
Andrew
para-sadistic
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
