HIGH RPM'S
HIGH RPM'S
I know our cars have a sticking rpm issue, but does anyone have this happen. If I am in 3rd gear around 3000rpm, and go into neutral or push in clutch, the rpm's will stay their for about 5 to 10 seconds.
Has anyone been able t ofix that with a tune?
RE: HIGH RPM'S
I have had this happen a handfull of times to me since I owned the car I am pretty sure it was before I was S/C don't think its happen since so it might be able to be corrected in the tune.
FWIW from what I remember it would only happen if say I was coming to a stop at a light I would just take it out of gear ( I believe third into neutal)instead of pushing in the clutch or down shifting. This is when I noticed that the rpms would stay at the same rpms (sometimes) I was at before I took it out of gear, but I noticed when it happened as soon as I would then push the clutch inthen rpms would thendrop.
So ever since then when ever coming to a stop or slowing down I always push the clutch in then pull it out of gear into neutal and don't remember the problem happing again.
