Gas Gauge Issue? Need Opinions and Fix-Its PLEASE
Hey guys!
So I think I've seen something like this posted in the past. I'm not sure if I'm having the same related issue but here it goes.
Yesterday (Tuesday)night, I got home from work with only 1/8 of a tank low from being full. I filled her up on Monday night. When I started her up this morning to go to work, the gas gauge only went up to a 1/4 tank! I always let her warm up and I'm not parked on a hill...the gauge didn't move. When I started driving to work, the gauge gradually started dropping. Ionly have a 20 mile commute to work which barely makes a dent in my gas, nowhere near a 1/4 tank. There are no signs of leaking and I checked my gas cap and it's snug tight. I was hoping you guys could tell me what exactly might be wrong (thinking the gas level sensor) and how to fix it...can I take it to Ford and will my warranty cover it?
Thank you so much!!!
RE: Gas Gauge Issue? Need Opinions and Fix-Its PLEASE
Yes it is a warranty issue. I had the stumble after cruise TSB taken care of on my wife's 06. the replacement pump/level sender, acted just like you describe after they installed it. The next assembly has worked just fine. This is a known defect, do not let them BS you on this.
Paul
Paul
one of my friends had a somewhat similar probelm. he was driving and all of a sudden his gas guage went all the way to empty. it was just a sensor that went out.
I remember a while back someone reported similar problems and it was caused by his custom over-axle pipe that was not positioned right and started to melt some of lines/cables in that area. Hopefully that's not the case for you.
ORIGINAL: sycd
Don't know if the 6cyl is the same, but these cars have the craziest tank, level sensor, pump setup I've ever seen. There are actually 2 level sensors, one on each side.
Paul
Paul
AmericanMuscle4.6GT
11-10-2015 02:06 PM
