What #s can a N/A 08 GT make?
#21
RE: What #s can a N/A 08 GT make?
ORIGINAL: AmericanMuscle4.6GT
and apparently you haven't touched your heads......
ORIGINAL: nothsa
I'm at 345.9 rwhp N/A and am pulling better times than most blown s197's at the track.
Anyways I have the following "engine" mods:
American Racing Longtube Headers w/ Catted X-Pipe
JLT II CAI
CompCams Stage 3
CompCams Springs/Retainers
FRPP CMCV Delete Plates
Steeda UDP's
Dynotuned with SCT Software
I have about $1,000 in my suspension as well...
-Jeff
JLT II CAI
CompCams Stage 3
Steeda UDP's
-Jeff
I dont mean to be rude but come on.
From 270 at best at the rear stock, you gained around 80 rwhp by porting the heads, cams, and getting a tune?
#22
You wont see anything over 350 rwhp out of a N/A stang, not happening. Not logically at least. If you spend a ton of $$, stroke it out, blah blah blah sure you may hit 355, but its an extreme longshot, also like $12,000 later. Im happy with my 308 rwhp and the flip of a switch at 422 rwhp and 508 ft/lbs of torque.
Staying N/A on these cars are cool, but there is a limit, and at 340-350 rwhp id say thats a low limit.
Get a turbo with a boost controller, run 4 lbs all day and pump it up when you race. That car should easily last as long as a N/A car. No matter what you put on these cars if the tune is good and you take car of it, it will last.
#23
there's a good, activethread on cams here: https://mustangforums.com/m_3819388/tm.htm
I think 380 rwhp is a reasonable target if you're willing to do the heads. I've spent $3800 on power parts to get to 350 and I haven't even done anything to the heads yet.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
