suspension and wheels
RE: suspension and wheels
ORIGINAL: Ford_Dude
did you remove the little clips
I remember from someones post that ford puts on these little clips on upto 3 lug bolts per wheel and if you don't remove them then you'll be unbalanced
Your swaybars won`t make any difference at all. And unless you are changing sways for a specific reason they may not even help your handling.
Pull the front wheels/tires off and do a thorough visual exam. Run your hand around the diameter to see if you feel any lumps or dips that may be signs of a broken belt. If you can`t find anything then take them down to a local tire joint and have them spin balanced.
Eric
Eric
The major focal point here is have the tires rebalanced. I have had tires balanced and had to take them back almost immediately because they were not done properly. When you do things on your own, fix one item completely, before going on to the next. Tearing apart more items just broadens the items that need to be checked and debugged to get it fixed right.
ORIGINAL: whitty
I am gonna check them out today and see if there is anything physically wrong, and the have them rebalanced. Thanks for the input.
https://mustangforums.com/m_2044381/tm.htm
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
