what do i need for gt500 front end?
well my front fascia got hit in a parking lot and now im thinking about instead of getting another stock one to replace it, that i should go for the gt500 front.. what exactly do i need? the fascia(bumper), gt500 headlamp lense, and maybe a new grill? please tell me if im wrong and correct me
RE: what do i need for gt500 front end?
you need alot of parts.....comes to about 1500 plus paint costs.
http://www.fordpartswebsite.com/
Give them a call and they can set you up....personally the cost is not worth it to me. I wanted to do the same but i can spend 1700-1800 elsewhere
ORIGINAL: bmk
Not cheap but what an improvement! It's worth the money in my book.
You need: front cover $543.83
head lamps $138.18 ea.
fog lamps$116.07 ea.
upper grille $209.08
lower grille $154.77
chin spoiler $61.60
deflector/shield $33.33
Those are last Friday retail quote from Ford... You have to add paint and labor, you'll be in the 2 grands neighborood.
I'm fixing to do that job within the oncoming 2 weeks (parts are ordered) for a customerandI know that there will be more odd parts. Like maybe the fog lamps harness, they have to be longer than the GT.
You've got a basic idea now, good luck.
I think you will need more than listed above....
Parts List
[ul]
7R3Z-17D957-APTM ,1, Bumper assembly
7R3Z-17K945-AA, 1, Grille, lower
7R3Z-8200-A, 1, Grille, radiator
7R3Z-8B455-A, 1, Bracket
7R3Z-8B455-B, 1, Bracket
7R3Z-17C861-A, 1, Reinforcement
7R3Z-17C861-B, 1, Reinforcement
7R3Z-17626-AB, 1, Lower valence (optional, it wont impact the appearance of the bumper without, fastener holes are under the vehicle)
7R3Z-17C882-A, 1, Isolator
7R3Z-15200-A, 2, Foglamp (see Note 1)
7R3Z-14290-EA, 1, Wiring harness (see Note 1)
7R3Z-8C291-AA, 1, Shield
7R3Z-13008-A, 1, Headlamp
7R3Z-13008-B, 1, Headlamp
5R3Z-16103-AA, 1, Guard, front (see Note 2)
5R3Z-16102-AA, 1, Guard, front (see Note 2)
[/ul]
Fastener List
W706805-S902, 10, Screw (diagram says 6, but it’s 10, you can get away with less)
W302597, 10, Bolt
S713547-S439, Nut, spring (unsure if nut spring is for screw or bolt)
W711274-S439, Nut, spring (unsure if nut spring is for screw or bolt)
Rivets, 4, Diameter 3/16", Grip 1/4" (there's an official Ford part for the rivet, but I chose to purchase some at a hardware store)
https://mustangforums.com/m_3444863/tm.htm
Parts List
[ul]
[/ul]
Fastener List
W302597, 10, Bolt
Thanks for him 'howarmat'. He's got $900 credit though (kinda).
When I did my GT/CS conversion, I left out a few partsand fabricate some spash shields connecting with the fender liners so everything's sturdy. I saved $100 with 5mn labor and free materials. If he's got a good shop, he might be able to save a few bucks.
Also the V6 and GT grilles are really flimsy, from the factory,at the top where they attach with the radiator cover. It makes the fog lamp shaking a little over bumpy spots. Hate that crap! I made L shape brackets that connects directly to the radiator support.
Do you have that issue or is it me?
Other Professional Racing
09-10-2015 11:41 AM
