Help with oil tem gauge
I had an Auto Meter Sport Comp II oil temp (electric) gauge installed and I am not sure it is working right. If I am driving the needle doesn't move from the lowest point on the scale, 140 F. If I stop and let the engine idle it slowly moves up; start driving and it goes back to 140 F. Is this normal? What should I see as the normal operating temp while driving? Thanks in advance.
RE: Help with oil tem gauge
ORIGINAL: Salas
Which wires did you pick-up for ground and power?
Is it installed correctly? Did you install it yourself or
have a speed shop do it? Why do you think it is not
working? Borrow a DashHawk and see if the readings
match.
ORIGINAL: Burnsy
from that terminology i would assume he means he had a shop install it
ORIGINAL: Salas
if it is not working or misreading the temps. If you didnt install it,
its kinda hard to troubleshoot it. It should read at least the coolant
temp during normal driving + some.
The gauge was installed for me. Doesn't any one have an oil temp gauge and knows
what temperature it reads under normal conditions? All the other stuff about why an oil temp gauge,
why not a DashHawk, etc is irrelevant.
According to this web page:
http://books.google.com/books?id=qWJ...TOb6UvC4_gNOpU
it should be between 220 and 240 F.
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
