finally sprayed 125 shot on a good track
RE: finally sprayed 125 shot on a good track
WOW!!!
Congrats. I think I really hate you. LOL....
I am almost ready to try my 150 shot. Just waiting for dyno tune and a couple of other odds and ends. I will be happy breaking 11's
Thurman.
Thurman.
Thanks guys, now if I only had jerjan's blower, but I need to build the bottom end first. It was a cool evening, about 65 or so and everything was working great. bought my wheels from powerhouse performance in moore ok. and only rearend work is lowering springs on the rear and 4.10s. next mod will be the AJE front K member and QA1 front struts.
Wow so you are running the stock suspension in the rear with just lowering springs? Great to know you can run 11's with it.
Those are some great times. Congrats. [sm=icon_cheers.gif]
I would assume you are running slicks right?Because Im running a set up close to yours with nittos(555r's) & cant get it to hook in first on the spray.I am getting ready to do QA1 adjustables in the back though.That should help.
ORIGINAL: 06tyrfryr
I'm spraying off the line with 14 lbs tire pressure and with some heat in the tires it hooked great.
ORIGINAL: 06tyrfryr
Andrew
