QUESTION ABOUT PYPES OFFROAD H PIPE
RE: QUESTION ABOUT PYPES OFFROAD H PIPE
well good question.......
the Pypes O/R H is a DIRECT OEM REPLACEMENT part......i just installed it on my car a couple of weeks ago and it bolted on right in between thestock headers and the stock over-axle pipes.....ifthe LTs are the same specs asstock headers, then your fine, but any deviation from the stock header specs which changes the lengthor diameter, it might require some modification for it to fit right....
The Off Road H Pipe is made for shorty/stock headers. If you put longtube headers on, the pipe will need to be modified to work with them. You'd probably be better off at that point to sell the Pypes piece and put one in that's made for long tubes. It could be a bit hard to get them to line up even with modification, and you could have leakage problems unless you weld them together.
09-10-2015 08:39 PM
