Rocker Panel Stripe?
Ok now Ive heard that to take these bad boys off I need a hairdryer and goo gone? Has that worked for anyone here? Where can I buy goo gone- like a hardware store or autozone? Or are there any other suggestions?
Im open to any helpful hints!
Also I dont like the white stripe on my alloy metalic but since im going to make some changes and have black accents I dont think Id mind getting a rocker panel stripe in black down the road. Anyone know where I can find a really good one- I kind of want it to be more unique.... not sure- I remember seeing this bad ace one on a screaming yellow pony here but cant remember who's it was
Again any help will be appreciated
RE: Rocker Panel Stripe?
I've seen it at some of the grocery and drugstore chains here in S. Fla. probably Walmart too if I had to guess...
also here: http://www.autobarn.net/mgcgg12.html
but have you used it? I mean theres automotive speciality ones and I dont want to use the normal stuff if its gonna damage my paint?
I kinda want to do this tonight so gimme some advice here guys!!!
If you have patience and a steady hand, it's easy as pie. You don't really need a blow dryer depending on whereyou live. I did mine here in the Bay Area in May where it was about 80 degrees. If it's too hot, a blowdryer will melt the adhesive on the stripe and it will stick a lot worse. I actually washed the car first, which I think helped. Just use a razor blade on the edges to lift the decal, then slowly start to peel it back. Everytime it breaks apart, just continue the routine. Only use the goo-gone if you have sticky residue leftover. Before you use it, I recommend washing the car first after you remove the decal too. I didn't have to use any adhesive remover after I washed my car first. Goo-Gonecan be bought in the hardware section at WalMart, Target, ACE Hardware or Kragen.
I used it to remove the dealer sticker from the back of mine and it worked fine - no damage to the paint. Just need to apply it a couple of times on the more stubborn parts. Then you need to clean and wax the area.
As for a unique stripe - see the top of this forum under Tacobill's install instructions for a very nice fading stripe. Also try Baltimore Street Mods or Bob White or Graphic Express.
Good luck!
Good luck!
Thank you much- esspecially the advice about not needing a blowdryer if you live where its hot. Im in Texas and its like 90+ degrees outside right now and prob wont start cooling down till around 8
ORIGINAL: MlissaG
Thanks for the help everyone- I just went outside when I got home this afternoon and used my fingernail to get an edge started and the stripes came right off. I washed, clay bar'd and waxed it to and it looks bEautiful! Thank you again for the help. I really like the outcome and now I cant wait to get started on other "mods"!
ORIGINAL: MlissaG
