GT 500 Front Chin Spoiler "PICS"
RE: GT 500 Front Chin Spoiler "PICS"
First, Thanks for the compliments.You must first remove the toptwoend egg crate looking sections but leave about 13/16" at the end that is nearest the centershort straight piece that separates the center egg crate section. This will fill upthe center section of the front fascia when mounted.. I did not want to drill any added holes into the original panels so I opted to drill 2 extraholes in the spoiler on each side to be able to use the existing screw holes for the 2lowerscrews in the fenderwell area. I used Dorman's 5/16" black nylon rivets part# 799-100 to fill the 10 holes that are molded into the front top of thespoilerthat will show when mounted.I also used 10 5/16" stainless washers on the bottom sideof the spoiler to hold the rivets in securely.Underneath I removed the 4 centersilver colored screws that hold the front fascia to a black panel that probably is used to shield the engine from anything flying up into it from underneath. The spoiler has 4 holes in it that line up with the factory holes. The most tedious part was removing the egg crate sections but in the end itadds so much to the front end and at an affordable price too. I would be glad to answer any more questionsyou can e-mail me at hanks4speed@sbcglobal.net
[IMG]local://upfiles/13839/B13717AB59554B20B85F9633F7A45028.jpg[/IMG]
ORIGINAL: Jackies Stang
Looks great! Run into any problems with the install and how long did it take?
The hood scoop is made by 3D Carbon. I like it because it fills up the hoodbetter then like a Roush orfactory Ford scoop. It's probably been on the car for about 2 years now and is held on by the 3M tape with no signs of lifting or coming loose.It really looks nice from the inside also when your looking out over the hood.
[IMG]local://upfiles/13839/7179FB17DBD5456BBC031AAB6D534A6C.jpg[/IMG]
[IMG]local://upfiles/13839/4C724E5FA1C143BF9CE63D86D88E7D0A.jpg[/IMG]
ORIGINAL: nh3
That looks good. I've been kicin round the idea of that spoiler and selling my cdc classic. Is that a 429 scoop? That's on my shopping list for sure. Going to pick up the 429 scoop, side window louvers and a rear spoiler the fire up the paint guns and spray.
To each his own !!!!!!!!!!!!!!!!! Also the GT 500 Front Clip comes with the same splitter if you buy the whole package so you might want to consider this.
[IMG]local://upfiles/13839/C4C03F917CD1436A97CDED332AFC4448.jpg[/IMG]
[IMG]local://upfiles/13839/C8183F1BBFBA4980B333B159790A9881.jpg[/IMG]
Look at the pictures of mine. Near the wheellwellit will stick out about 3" at the lowest point from the bottom outside edge of the fascia. As for depth it is about 7" all around except in the middle where the spoiler front indents in the area of the lower grill there it is about 6". There is about 3" of spoiler sticking past the bumper that is seen from outside.I was able to use the 4 mounting holes under the center of the fascis which are silver in color. There are 4 holes in the spoiler that match up close enough to these holes to use them to mount the spoiler without drilling added holes.Thisis about where the spoiler will reach under the car.
[IMG]local://upfiles/13839/49DDB5790B7F4ABDA72E27F9D20ADC24.jpg[/IMG]
[IMG]local://upfiles/13839/1128A788370C466880B14B680C37A1CD.jpg[/IMG]
ORIGINAL: tdogg74
Could someone tell me what the dimensions of this is? Specifically, over-all length across, and especially the portion that attaches to the bottom of the bumper.
thanks
-Trav
thanks
-Trav
