my car has a ghetto lean
my car seems to always appear to lean to the drivers side a little, warranty? or is this something i can adjust myself? im very bad with suspension parts... as far as what does what... im very mechanically inclined... but with suspension, knowledge deficient...any suggestions?
RE: my car has a ghetto lean
It's normal and as far as I know all fords do it. It becomes more apparent when you lower it. I spent lots of time trying to even out my 99 ford ranger and finally did it with a 4 corner adjustable air suspension.
If Im correct... Our cars lean towardsdriver side based on the amount of gas. Full tank means biggest towards driver side. Empty tank evens out with left side.
Keep in mind "lean" isnt the most accurate word. I think "sway" is the best word.
In other words with a full tank of gas the car will sway towards the right and you can basically see more of the passenger side tire, from the top. Best way to describe it...
ORIGINAL: urnamethere
i guess i know why my car doesnt lean to the left
I would never accept my car leaning to the left! Hell no!To the right's fine though
hmmm so this is "normal"?... It isn't like a spring settled or lost its springiness? Would this even be something that they would look at under warranty? If it is normal... then ok... shweeet...
